Old Town with number 50233
The Old Town canoe with serial number 50233 is a 17 foot long, AA grade, Charles River model with red Western cedar planking, open mahogany gunwales, mahogany decks, mahogany thwarts, mahogany seats, a keel, outside stems, and a floor rack. It was built between September, 1917 and April, 1919. The original exterior paint color was dark green with a four inch N. H. (New Haven) green stripe and turned down ends. There was also a four inch old English style "H" in gold on the border stripe on the left bow and right stern. This may have been similar to one shown at http://www.wcha.org/catalogs/old-town/designs/design10.gif which was later known as the design number 10 although the gold stripe separating the two colors was not mentioned on this build record. It shipped on April 12th, 1919 to Smiths Ferry, Massachusetts. A scan of this build record can be found by following the link behind the attached thumbnail image below.
This scan and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. Additional information about the project to preserve these records is available at http://www.wcha.org/catalogs/old-town/records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/wcha/ to learn more about the WCHA and http://www.wcha.org/join.html to join.
It is also possible that you could have another number or manufacturer if this description doesn't match your canoe. Please attach a picture if any of the original design is still showing. Feel free to reply here if you have any other questions. Good luck with the restoration,
Thanks, Benson, very much. The boat has mahogany bungs instead of the diamond heads on the inwales. I think they provide a much cleaner look than the diamonds, so happy to have them. See you soon. Dave
Yes, the diamond headed bolts didn't appear until around 1922 on the CS grade models and several years later on the AA grade ones. It is a nicer look. I just registered for the Assembly so will see you there,
