The Old Town canoe with serial number 76162 is a 17 foot long, CS (common sense or middle) grade, HW (heavy water) model with red western cedar planking, open spruce gunwales, birch decks, birch thwarts, birch seats, a keel, outside stems, a floor rack, sponsons, and a bang plate along the full length of the keel. It was built between January and May, 1923. The original exterior paint color was dark green. It shipped on June 9th, 1923 to New York City. The back side of the card indicates that it had moved to Niantic, Connecticut when there was a previous request for a copy of this build record. Scans showing both sides of this build record can be found by following the links at the attached thumbnail images below.
These scans and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at
http://www.wcha.org/catalogs/old-town/records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See
http://www.wcha.org/store/membership to join.
It is also possible that you could have another number or manufacturer if this description doesn't match your canoe. Feel free to reply here if you have any other questions. Thanks,
