Old Town canoe build record
richardshank
Hi Benson,
Thank you for responding to ur serial number 16054 inquiry back in August 2026. The two possibilities you followed up with 160656 and 160657 were logical, but unfortunately we probably sent an incorrect number. The old stem is quite worn and getting a good read is a bit of a guessing game with different eyes reading different numbers.
We should have said back in August that the number was 160564, with the possibility that last digit could either be a 3 or an 8. Another possibility is a serial number 100504, again with the last digit uncertain and either a 3 or an 8.
The two records you sent us 160656 and 657 were canoes from the 50's. Our canoe appears older with thwarts and seats having more detailing to shape like canoes from the 30's. The seats were hole-caned. This canoe was also built with 4" wide planking typical of the earlier years.
One detail that may help solve the mystery is the bow deck which has an insert to accept a small deck flag.
The hull is shaped like an HW but with the bow and stern profile recurves characteristic of Charles River-Molitor.
Both stems had been replaced above the waterline with new (plywood) material which had been scarfed into the original floor stem section. This could have changed the profile look.
There is no indication that the canoe originally had either external wood stems or a floor.
Thanks again for helping us solve our canoe ID!
Dick Shank
Urban Boatbuilders, St. Paul MN
