Old Town Build Record
Larry Bowers
yellow cedar manipulator
Hi,
Would it be possible to get the build record for the following canoe. The serial number is 85723 16.
Thank you in advance.
Larry
The Old Town canoe with serial number 85723 is a 16 foot long, CS (Common Sense or middle) grade, HW (Heavy Water) model with red western cedar planking, open spruce gunwales, birch decks, birch thwarts, birch seats, and a keel. It was built between October, 1924 and March, 1925. The original exterior paint color was dark green. It was shipped on April 14th, 1925 to San Francisco, Calif. The back side of this card indicates that it may have moved to Harry Hill, Alberta by July 6th, 1976 when there was a previous request for a copy of this build record. Scans showing both sides of this build record can be found by following the links at the attached thumbnail images below.
These scans and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and http://store.wcha.org/WCHA-New-Membership.html to join.
