Old Town 17' serial number search
Roy
Have a old 17' Old Town the serial number is 8189 and would like to learn more about the origin. Have owned it since the 1965.
Thanks for your help.
Roy Auger
Moultonborough NH
The Old Town, Carleton, and Kennebec canoes with serial number 8189 are all 16 feet long. Can you take some pictures of the numbers and surrounding area from each end and post them here to see if there may be any hidden digits? The tips at http://forums.wcha.org/showthread.php?791 may also help. Many other builders used a similar numbering scheme. Some pictures of the decks, interior, and the rest of the canoe may also help identify it. It would also be good to confirm the extreme overall length of your canoe in a straight line as well. Thanks,
Old Town Serial number correction
Hi Benson
Thanks for the help looks like 81896 a closer look at the serial number reveals a possible 6 as the last digit with a space followed with the length of 17. I have attached pictures to help in the research as to the origin and model of my Canoe.
Thanks again I look forward to hearing from you.
Roy
The Old Town canoe with serial number 81896 is a 17 foot long, AA (or top) grade, HW (Heavy Water) model with red western cedar planking, open mahogany gunwales, a keel, a floor rack, outside stems, floor rack, and sponsons. It was built between November, 1923 and April, 1924. The original exterior paint was dark red. It shipped on June 28th, 1924 to Dover, New Hampshire. A scan showing this build record can be found by following the link at the attached thumbnail image below.
