With our new forum, some things are a bit different. I recommend that each user check their settings and be sure they are set the way you want them to be.
Access to your settings is easy. Your username is a tab on the menu bar up at the right. Click on it, and it will load the page with all the things you can change off to the left.
PS, if you are used to using the Private Message part of the old forum, they are called "Conversations" now.
