Scott: The outer stems on my Morris Mollitor are intact, but were not attached. The stem bands were missing. They show countersinked holes where they were riveted to the inner stems and show smaller holes where apparently the stem bands were attached with screws. The stem band holes are spaced irregularly, approximately 5 inches apart. There is one screw hole about 2 inches from the outer stem-to-keel joint. There is one larger hole nearer the ends of the keel, apparently for a screw into the splayed inner stem. All other holes in the keel are for screws driven at each rib from the inside of the boat. There is one small hole in each of the long-deck battens, about 1/2 inch from the peak. Hope this helps.
