ticonderoga
"Just one more"
I could use a little expert advise on my Morris restoration project. I am at the point where I am reattaching the top cap and outside gunwale to my closed gunwale Morris #4027. Up to this point I have been trying to keep as much of the original wood work and fasteners as possible. During some initial repairs and re canvasing, I saved all the nails that held the top cap and outer gunwale in place. After a hundred years or so some of the nails have broken or are bent beyond reuse. I have secured the top cap which is most visible with the original nails and have only enough nails left to do about 60% of the outer gunwale installation. The question I have is should I use as much original nails as possible and finish with new fasteners or should I just go with all new ones? Is there a source for "old style nails" or what is a good new alternative? Bronze ring nails, escutcheon pins, etc? Any advise from all the Morris fans would be appreciated. Thanks
