Howie
Wooden Canoe Maniac
I've started restoring a 16' Morris I was given a while back. There is no ID plate - perhaps it was lost when the first 24" of both front rails were hacked off in a previous restoration attempt. It does have mahogany seats, decks, and thwarts. And three cant ribs. From its dimensions (31-3/8" width to rails, 33-1/4" max width, and 24" height at the deck's tips) I'm thinking it's a Model A Type 1.
The rail caps don't appear to be in too bad shape so I'm thinking I might be able to reuse them. But the outer rails look to have been replaced as they are notched, not steam bent, to get them to conform to the rail's curve (see above pic), so I'm not sure what size they were originally. Can someone tell me the outer rail width & thickness?
Also... The planking ends at the bottom of the inner rail, and is tapered in width to just about zero thickness. I'm worried that someone will poke their fingers through the sides! - though I suppose the canoes has obviously lasted this long. Perhaps the side rails were wide to protect this area.
