Craig Johnson
Lifetime member
If a sailing rig was original equipment on a canoe how was the mast step attached? was it screwed down from the inside, screwed or bolted up through the hull before canvassing, or through the keel after canvassing? Did different manufactures use different methods at different times?
thanks, Craig
thanks, Craig
