The Old Town canoe with serial number 11577 is an 18 foot long, AA (premium or top) grade HW (heavy water) model with red western cedar planking, open mahogany gunwales, mahogany seats, decks, and thwarts, and equipped with a keel, outside stems, painter ring (2?), a mast seat, lee boards, rudder, and a leg-o-mutton sail. It was built in July 1909. The original exterior paint color was dark red . It was shipped to Philadelphia, Pennsylvania on August 5, 1909. A scan of this build record can be found by following the link behind the thumbnail image attached below.
This scan and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others. A description of the project to preserve these records is available at
http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See
http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and
http://store.wcha.org/WCHA-New-Membership.html to join.
For a discussion of determining the value of a canoe, see the post at:
http://forums.wcha.org/showthread.ph...en-canoe-worth
See also:
http://wcha.org/legacypages/catalogs/old-town/guide/
If you have all the sailing gear in good condition (mast, spars, rudder, lee boards, saiing seat) that will increase the value of the canoe quite a bit. If you have it, a sail from 1909 is not likely to be useful, except as a pattern for a new sail.
Greg Nolan
