laminated paddles
adkpaddle
I have a problem finding boards large enough to make single piece paddles from. I have decided to try and make a few laminated paddles from but I can't find a way to make the edges of the boards perfectly strait. I don't have the money to buy a jointer/planer or router table. I am looking for any helpful ideas.
Use whatever you have...
Do you have a router? You don't need a table for it. If so, try a 1/4" spiral bit using a straight edge to guide the router, keep the router in good contact with the board and straight edge, work at a good speed and don't try to take off too much at a time...1/8" or less. Clamp everything down good. This also sounds like a good time to become savy with a jointer hand plane and no dust flying around, also nice and quiet! Well tuned table saws with a good blade work as will a circular saw using the above mentioned straight edge and a good blade. Check some of the wood working sites for thin kerf planer blades and some hints. Many moons ago and no resources, I built a kayak and laminated paddle with only a circular saw...it works.
Best of luck...
Ric Altfather
Though obviously not ideal if you do a lot of rock bashing, I've been hacking Greenland-style kayak paddles out of carefully selected Home Depot cedar 2x6's lately and absolutely love them. They're lighter than my big-buck carbon paddle and balance better. Some are going on their third season and still look and work just fine. These three cost me a total of about $20 to make and canoe paddles would be even cheaper because you can use shorter stock. A cedar paddle may or may not make a good all-purpose paddle for you, but at that price it's worth building one to try just for fun. I rough cut them on the bandsaw and then do all the tapering and thinning with a spokeshave. They're light and lively to use. The paddle on the left is 7' long and only weighs 22 oz.
These are all made from single boards based on Calib Davis's design. The two outside cherry paddles came from a single 5/4" X 6" board for about $17 total. The middle paddle is from basswood...won't take a lot of punishment but really light weight, about $8. The more you laminate...the more weight you accumulate. Try Todd's advice by making one from a Home Depot 2-by...it's good practice, produces a good paddle and cheap! Then, you can move on to other woods or not.
