Kennebec Canoe
Pedro
Hello,
I have a 17 ft Kennebec canoe that had sponsons when I found it submerged in a pond in Jaffrey, NH in 1972. With help from friends I recanvassed it, replaced some planks and ribs and enjoyed it. After being out in the weather too long (my fault) it needs recanvassing again.
The serial number on the oval plate is 9476, can anyone tell me when it was made?
Thank you
Hello Pedro,
Is it possible for you to post some photo's.
It would be most interesting for you to post a photo of the noted tag.
Where is the tag located?
Is it attached to one of the stems, on the floor of the canoe?
Does it look like this tag?
The Kennebec canoe with serial number 9476 is shown on page 388 and 389 of volume one in the Kennebec ledgers. This was assigned to a 17 foot long Kennebec Sponson model, with spruce rails, ash stems, cedar planking, and maple decks. It was planked by Grant and Knowlton(?) on March 13th, 1915. The canvas covering was applied by Ray on March 20th, 1915 and he applied the first filler coat on the same day. He applied the second filler coat on June 3rd, 1915. The railed column has Doucette and a name that I can't identify followed by the dates February 5th, 1916 and July 10th, 1917. The next two columns are badly smudged so the original color, painter, and date are not clear although the year appears to be 1916. It was shipped to "J W Pa" on June 15th 1916. The inconsistencies in these dates are probably a clerical error.
The scans of these build records can be found by following the links at the attached thumbnail images below. These original Kennebec records are reproduced through the courtesy of the Maine State Museum.
The microfilms and scans of these records were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) as you probably know well. I hope that you will renew your membership or contribute to the WCHA so that services like this can continue. See http://www.wcha.org/wcha/ to learn more about the WCHA and http://www.wcha.org/join.php to renew.
More information about this and other Kennebec models can be found in the Kennebec catalogs contained on the Historic Wood Canoe and Boat Company Catalog Collection CDs available from http://www.wcha.org/catalog/ and http://www.dragonflycanoe.com/cdrom.htm on the web.
Some oval Kennebec tags look like the one at http://forums.wcha.org/attachment.php?attachmentid=6987&d=1233681832 here. It is also possible that you could have another number or manufacturer if this description doesn't match the canoe. Feel free to reply here if you have any other questions.
Thanks for all the info on the boat. The oval plate is tacked with 2 tacks to the bow stem on the floor of the canoe. I'll try to get some photos soon. Thanks again.
I know very little about Kennebecs. On the interior gunwale there appears to be 3 reinforcements that I do not see on the port side. Anyone have any insight?
I suspect that someone didn't want to replace the inside gunwale on the starboard side and this was a quicker solution. It isn't likely to have shipped like that originally. The link below shows a more typical looking Kennebec in better condition.
Makes sense. Always enjoy seeing the videos Kathryn put together and your access and service with so much information.
I just purchased Kennebec #9476 today, it is very good condition for a 110 year old canoe, they owner took good care of it.
Attaching a picture of the tag (note the stem) and of the canoe, the one on the right.
Bill Thurlow
They are repairs the owner did the reinforce the broken inwale, they were in college at the time and had limited tools etc. They did get it canvased and used it for many years. Been hanging in his barn since the canvas wore out
Bill Thurlow
