Dylan,
That really depends on how you apply the epoxy! Lets take a step back and look at the application methods;
- You are brushing on a layer of Gluvit day one, wait until it is dry, then apply three more coats over the next three days, letting each coat dry and sand between each coat. If so, I understand that you don't get too much of epoxy penetration.
This is how I apply the West System epoxy;
-A first coat to "wet out" the canvas (applied with a squeegee), followed by two or sometime three coats the same day to fill the canvas and build enough thickness to allow for sanding on day two and painting about four days later. However, as said earlier, you must use a firm but gentle touch it is easy to get to much penetration.
