Is Old Town Serial No 218428 a Tripper?
jenshen
I bought what I think is an early Old Town (oltonar) Tripper but I have no way to tell it is. There is only a 6-digit number 218428 but no model name on the hull. Any info available about this canoe? Thanks.
Jen
The dimensions alone will tell you if it's a Tripper. They're slightly longer than 17' (17'2" or so) and very deep hulls (around 15" at the middle). They also have a rather bulbous lower stem down near the waterline. None of the other recent Old Town had those dimensions.
The Old Town canoe with serial number 218428 is a 17 foot long Chipewyan model with aluminum inserts in the vinyl rails. It was built in August, 1977. The original exterior color was green. It shipped on August 22nd, 1977 to North Conway, New Hampshire. The back side of this scan shows that there was a line the length of the hull on the inside and small soft spots on both ends. Scans of both sides of this build record can be found by following the links at the attached thumbnail images below.
It is also possible that you could have another number or manufacturer if this description doesn't match your canoe. This canoe has some very distinctive dimensions as Todd mentioned and was called the Tripper in the catalogs before and after 1977 as shown below. Feel free to reply here if you have any other questions.
