Dave Aukes
I'm replacing the gunwales on a18 ft square stern Peterborough, the sides have a progressive flare out from the stern to the bow. When the inwales are installed they are not level without cutting the rib mating surface at an angle. This provides level bottom to attach the thwarts.
I cut the gunwale stock square because of the progressive flare now as I install the inwales I have to angle the inwales to match the changing flare of the sides.
Any ideas on the best way to cut the progressive angle on the inwales as I install them? I'm thinking of using a bench plane.
