I'd assumed that I would need to wait until spring but our daytime highs have been in the 60s (Elk Grove, CA). It's been dropping into the high 30s/low 40s at night and I'd be painting outside on a covered patio. I'll be using Interlux Pre-Kote Primer with Interlux Brightside Polyurethane as a top coat. Both cans say that the application temperatures should be 50 degrees F and above but since we're only above 50 from about 10a to 7p, I'm concerned about proper drying. Relative humidity varies from about 50% to 90%.
Since I probably wouldn't use it until spring anyway, should I just wait until we're consistently in the high 60s to 70s and night-time temperatures aren't so low? I'll be painting a new bottom and want to get the best finish I can.
