Hi,
I recently purchased a 1946 18' Old Town Guide canoe that was part of a fleet up on the Au Sable river in Grayling, MI. Now I'm wondering if she's just 'tired out'. The hull is fairly sound and has a very good shape--at least by my eye. It needs a full restoration: remove fiberglass, replace 6-8 ribs, replace 2 or more planks, gunwales, thwarts, decks, keel, bilge rails, re-do the seats, install canvas. Even when I add all this up it still doesn't seem to me like too much work or like it's just not worth it. I looked the hull over carefully from several angles before I bought it and determined that it a very smooth, pleasing and uniform shape. The gunwale line doesn't flow real smooth, but that's because they pieced it together in a previous repair. I think a good set of new ash or even mahogany gunwales should take care of that. But my question and concern is this: while the hull has a good shape, is it possible that the ribs might just be 'tired out'? She seems to flex very easily, even with the fiberglas covering. When I set it upright on sawhorses with just the weight of the canoe (maybe 80 lbs) it flexes right over the 2 x 4s--not a lot, but noticably. The interior of the hull was also painted at some point so I won't see everything until its stripped. I don't have any other wood-canvas canoe to compare it to so I'm not sure whether this amount of flex is normal. Do the white cedar ribs and red cedar planking retain their flex indefinitely, or do they reach a point where they've seen so much work that they've gone 'over the hill'? You guys that do this for a living or just know these canoes a lot better that I do have a lot of invaluable input. Thanks, ahead of time.
Jonathan
Ypsi Township, MI
Jonathan
Ypsi Township, MI
