Copper Tip
Craig Johnson
Lifetime member
Hi all.
I am wondering if anyone can point me towards any information,or photos, of how to make copper paddle tips. I made a mandrel the same shape as the tip of my paddle but as I expected a quick try with a scrap showed me it would kink. Any ideas?
Wouldn't a rig like this leave the paddle tip prone to water damage & rot? Especially with nails through it...
I have thought about the possibility of rot from holding water and penetrating the wood with tacks or rivets but will varnish after the tip is on to try to prevent that. I really just want to try it as a design element, also after using my new paddle just two days on a shallow river I had worn some varnish off the tip so constant maintenance is required either way.
Have you tried putting laminating epoxy on the tip? If you clamp the paddle with the tip up, and put the epoxy on the tip, it soaks in... keep putting more on the tip until it stops soaking in. After it cures, sand & varnish like normal. It's not bomb proof, but it holds up well on the shallow rivers around here.
I have three halves of Rushton double-bladed paddles - all three are somewhat the worse for wear, but not because of the copper tips. These came out of a livery in Canton, NY, so were presumably abused.
The paddle on the left has a copper tip that was put on in two halves, joined along the edge of the tip of the blade. The paddle on the right has a square tip, and the copper was first folded over the tip, then again over the sides (like a Christmas package). The paddle in the middle has the classic one-piece mustache tip. The shape of the mustache allows you to bend the copper to shape in one piece.
There is a description on this in Graham Warren's first book, "Making Canoe Paddles in Wood." It is too bad this book has become hard to find, because in my opinion, it is far better than his second book with Gidmark.
Another thought - your success may depend on the state of your copper, so you may want to anneal it before you start shaping it, and perhaps again during the process, as copper will work-harden.
Interesting that the rot doesn't seem to have gotten started. How did they treat the wood to prevent that?
Thanks Dan.
The sharp curve of my paddle tip is what is causing my problem in trying to just peen it into shape. I am going to try to do 2 halves with the seam along the edge of the paddle which I will solder. will show photos if it works.
Craig
I doubt they did. Paddles are spruce, best I can tell. They were factory-produced, and at least one, if not all three, pre-date 1905. All extant damage is from use, particularly the two-pieced tipped one (on the left in the image above) - the tippy-tip is separated from pushing-off, and the blade split completely to one side of the shaft and was repaired with copper plates clinch-tacked into place. No rot evident. but, these are the survivors!
The following info about copper will explain why the tips don't rot:
Copper(II) ions are water-soluble, where they function at low concentration as bacteriostatic substances, fungicides, and wood preservatives.
Happy paddling,
Paul
Oh, duh... this is why copper has been used as flashing on roofs... and the copper-based slurry used in pressure-treated lumber...
With enough wet/dry cycles, it will still eventually rot around the fasteners. It's just a matter of time and maintenance (or lack there of). It will also vary with wood species - ash most likely being one of the most vulnerable with the black fungus it gets. With the limited use and exposure that paddles get, you probably won't live long enough to see serious structural rot unless you have some very strange storage practices for your paddles. Still, it certainly wouldn't hurt to stick a little something in the holes to help seal them before driving the rivets in. Splits are probably a greater danger than rot, since the holes make a pathway into the end-grain for water intrusion. Obviously, tipped or not, well maintained paddles last longer.
progress
OK, so here is my first attempt. I am pretty happy. Slips right on like a glove, fits nicely, maybe a little epoxy before I put it on permanently. Seems like a good place for some art,whatever it's called when you emboss a pattern in copper. Possibly in the future leave the paddle tip a little oversized in order to relieve the copper tip into the wood and trim flush, small detail, maybe not worth it. Still have to polish it and decide on fasteners, then a couple more coats of varnish. More photos then.
Craig
Looks pretty nice! I wonder if there might be a better top coat for it than varnish. Maybe lacquer? I don't know, just wondering, & hoping someone might have experience with this. It may not matter.
Copper paddle blade protector: Gauge?
This does look nice. and obviously, some nice soldering!
I've also been thinking about how to put a copper protector on some paddles. We had a standing seam roof put on the house this summer. I asked and the contractors dug out and gave me some waste copper roofing from another job. I'm thinking it looks thinner than what you are using. Do you know what gauge your copper sheeting is?
I am not sure what gauge it is. I had lots of scrap from coil stock I use to flash chimneys on slate roofs. If I talk to the suplier soon I'll ask.
Craig,
I would be interested in the technique you used to fabricated your most recent paddle tip protector and eliminate the wrinkles. I made two sassafras paddles for a close friend who is an avid paddler and a very hard man on paddle tips. After two trips back to the shop to refurbish the tips he asked if I could put some kind of protection on them. Your brass tip seems to be just the ticket for him.
Ed
Hi Ed. So here are some photos of the 2nd attempt. I made a mandril the same shape as my paddle.IMG_1927.jpg I used aluminum because it was easy to shape and helps conduct heat in soldering process. I also made a template for the copper and bolted on a couple pieces of wood to hold the copper in place because on the first one the clamps left marks.IMG_1928.jpg Here is the first piece of copper in place.IMG_1931.jpg Here it has been rolled over with a hammer and the second piece is in place.IMG_1935.jpg Here the second piece has been rolled over the first and then removed to clean and flux the outside of the one on the mandril and the inside of the other.IMG_1936.jpg Then they are put back together, a little final hammering and some spring clamps and ready for soldering.IMG_1937.jpg Propane torch and get it to suck into the joint,just like copper pipe. thats pretty much it, clean up with a file and sandpaper then polish. I'll send more photos when I get it cleaned up and figure out how to attach it. You may have figured I have been messing around with this longer than it took me to make the paddle. It will be quicker in the future.
Craig
