Chestnut model ID?
patrick corry
solo canoeist
A photo of the stem number is: 9271 15 Ex L
Owner (seller) says it measures 15'8" x 36". I don't know if the length measurement is from stem band to stem band at the tip of the gunwales, or from the most distant part of the stem curves. Width may be from outside to outside of the outwales, rather than the planking width.
I suspect it would be considered a 16' boat, and the Chestnut info I have lists the Pal at 34". It also lists the Pal as being built with one thwart.
Your thoughts?
I thought that as well, and my info indicates that the Bob's has a "tapered keel", while the Pal was built with "flat shoe keel". Another point 'against' the Bob's ID is that both charts list that model as 15'. The canoe in question measures 15'8" according to the owner. Both models are listed at 12" depth. See the attached charts. The second chart is , I think, more recent.
The Bob's would be more desirable for me, as it's listed at 55 lbs! Nicer for solo tripping!
The things that argue for it being a Bob's is that it has a single thwart, heart-shaped decks, and looks to be quite beamy. That's not a shoe keel shown in your photos. Also, dimensions given in Chestnut catalogs are quite unreliable.
Its a Bobs. As Dan said, dimensions vary greatly from catalogs, and moreover there were many boats built that deviated due to special orders from customers, or changes in/unavailability of, materials. Most recently i dropped a Chum to a depth of 11.5" with new rails, from its build depth of 13.5.
I think you'll find even "Ca Ira", Trudeau's canoe at the CCM has a discrepancy in the tag, where it says it's a 16 foot canoe, but is what's catalogued as a 15 foot 50lb Special. You'll also find that like yours, it's a very early example with that version of the Chestnut decal believed to indicate a pre-fire build.
I'm curious to know when the decks might have changed from the heart shape to radiused. Or, perhaps the heart shape was reserved for the 1st grade boats over lesser grades?
The heart-shaped deck was always* used on the Bob's Special.
The telling features of prewar Chestnuts are the lack of wide cant ribs and the shape of the stem at its tip (left wide pre-fire, bevelled to the tip post-fire).
* Always - a word meaning without exception, until the exceptions show up. :)
Hi Dan, just some observations.
There are examples where it appears the wide cant ribs were used before the 1921 fire, one early one is the sponson canoe at the CCM that is dated to 1911 by a rental plaque on the bow deck. It has the 3+inch wide cant ribs if I remember properly. I have photos somewhere. Even Ca Ira has wide cant ribs (photo attached) and it's supposed to be 1918. And I have an early cruiser from that era that has 2 inch inch cant ribs (not wide, not narrow).
It also appears that the pleasure canoes used the heart shaped decks, crowned and undercut, and the cruisers used the thumbnails, also crowned and undercut, from very early on. This can be verified in the early catalogues. Later the heart shaped decks appeared on the cruisers too.
I'm not sure all the early boats had the notched stems, certainly the pleasure boats did appear to.
It's a good reason to get back to the canoe museum when things open up.
That early decal was another pre-21 indicator, although Dick P. said it's possible they had some stock they used up later.
The closed gunwale canoes were also pretty much gone by the mid teens, and the open gunwales took over very quickly after about 1910, even though it appears they could be special ordered for a while longer.
As you said, this isn't proof, these observations may have other explanations. It doesn't help that it's not easy to get verifiable build dates on Chestnuts ! OT style records would have been nice.
