Canvas mits
ken mueller
Canton, Ohio
I needed to make several canvas mits for smoothing the canvas filler. Can't sew. After cutting out the right size for the mit, I put a bead of Gorilla Glue around the edge, then pressed both pieces between a board with a car battery on top. Did 8 mits all at the same time. Works great!
Regular wood glue works well, too. Been doing that for years. I highly reccomend the adheisve sewing technique. Don't really need the battery, just press tight and wait.
I've tried the stapler method, too. Glue is a nicer result, but with the staples you're ready to go right away if you've forgotten to glue up a mitt in advance...
I took an old wooden cement trowel with a handle and tacked some rug around it. Then I stapled left over canvas to that and when it is saturated I remove it and staple on another piece...........works fine for me for that first good rub in!
What am I doing wrong?
great ideas about 'mits' But when I go to rub in the filler I tend to stick to the filler and smudge it up. makes it less smooth. Any hints?
:) In Rollin's description in his book, he suggests only doing a litttle section at a time, having a helper roll it on, and then following with a good rub in while it is good and liquid...I dont have a helper but switch tasks very efficiently! havent had a problem so far!
Oops!
:confused: Oops.........maybe it was Jerry's description!......Now I will have to check to see who does it that way!.........anyway........it works!
Wow! I thought I had a novel idea with the Gorilla Glue! Looks like a lot of you beat me to it. Same thing happened when I invented the internet...
Where to buy Canvas mits
I would like to know if anyone can tell me where to buy canvas mits? This is my first canoe that I'm restoring. I want to do it rite. No half _____
Brian H Derose
Brian - read further back in this thread - plenty of suggestions for using work gloves, or DIY from the canvas scraps you will have. You are just rubbing in goop, not painting a Picasso, so any solution works.
canvas mit or glove?
Would cotton canvas gloves work? If I were to use a mit would it go on smoother?
