Build record for OT 184959 15
The Old Town canoe with serial number 184959 is a 15 foot long Light Weight model with a keel, outside stems, and a bang plate on the full length of the keel. It was built between April and May, 1970. The original exterior canvas covering was dark green. It shipped on May 28th, 1970 to the Scotia, New York. A scan of this build record can be found by following the link behind the attached thumbnail image below.
This scan and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/wcha/ to learn more about the WCHA and http://www.wcha.org/join.php to join.
It is also possible that you could have another number or manufacturer if this description don't match your canoe. Feel free to reply here if you have any other questions.
