Build Record for OT 123141
The Old Town canoe with serial number 123141 is a 16 foot long, CS (common sense or middle) grade, Yankee model with open spruce gunwales, ash decks, ash thwarts, ash seats, and a keel. It was built between October and December, 1937. The original exterior paint color was dark green. It shipped on May 9th, 1938 to Portland, Oregon. A scan of this build record can be found below.
Thanks as usual Benson. It never occurred to me to ask this, but the records list "Hull Varnished" and "1st Varnished" and "2nd Varnished". What was being done in these steps? Was Hull Varnished on the exterior and the 1st and 2nd Varnish on the interior? Or, was the interior the Hull Varnished and the 1st and 2nd Varnish over the exterior paint?
Pat, glad you asked. Pretty new to all this and that is something I have wondered about looking at build sheets.
There is no one left alive who can give us a definitive answer so your guess is probably as good as mine. The sequence and timing seems to indicate that the interior of the hull was varnished just before the canvas was applied and then two coats of varnish were added to the interior just before it was put into storage. My older brother indicated that the first sealing was to make it easier to remove any filler or paint that might get on the interior during the later manufacturing stages. The processes also probably changed over the years as they experimented with different sealers and approaches.
