Build history of Carleton #18516
Frank Devlin
Found this canoe in a dumpster. Has a Carleton nameplate on bow deck, open gunwales, diamond head bolts. Looks like spruce outwales, ash inwhales and seat frames but most everything is coated with latex paint so it's hard to tell. As best as I can determine serial #is 18516. I intend to restore this find to its former glory. Any information on this canoe is appreciated.
Frank Devlin
#18516
Frank,
Looks like this boat was shipped on August 14, 1911, to Coatsville (sp), PA. It was built in a "GS" grade and an 18' "SF" model. It was also ordered with a keel, middle thwart and the original color was "slate" . A build record is attached.
Frank, if you are not already a member, please consider joining the WCHA to help support the effort and financial resources that keep this service continuing. Also, you mention that you plan to restore this fine old canoe...this site has the best information from the experts that you will ever gain.
Good luck with your restoration and send pic's when you get a chance.
Regards,
Ric
Ric mistakenly posted the Old Town record. Attached is the correct Carleton record for your canoe.
These scans were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as described at http://www.wcha.org/catalogs/old-town/records/ in more detail. If you are not already a member, we hope that you will join or contribute to the WCHA so that services like this can continue. See http://www.wcha.org/wcha/ and http://www.wcha.org/join.html for more information.
Gentlemen, Thanks for the quick replies. As for the first build record- I was wondering how I measured so wrong or if my tape was missing a couple of feet. I will be joining the WCHA in the next few days. This is a great resource. Thanks again,
Frank
