samb
I’m nearing the time when I will refit missing/ damaged planks on my Wide Board & Batten canoe. Having searched high and low across the forum I have found a fair bit of useful information but I have one big question that as yet has no answer. Possibly there is no answer or there may be many but I would really appreciate some input from anyone with knowledge of WB&Bs and especially anyone who has replaced a plank; in fact any opinions from anyone at all might help me come to a decision.
All my ribs are repaired / reinforced (or soon will be). The damaged plank is #3 of 4. My lime is already to bend – and I know how that is supposed to work (except should I soak the plank first? – but that would get both sides wet and might hamper the bending process?) – but what I can’t work out is whether I should bend the plank before doing any edge shaping, or should I shape and fasten one edge before attempting to bend and then shape the other edge while everything is still hot and fasten that – or may be let it cool to its new shape and then scribe the shape I want.
My thinking at present is that doing all the bending first then use a planking gauge to fit would give me more time to work so lessen the chances of messing up. I’d put spacers over the ribs so as to avoid flat spots. I know the curve would be slightly large but reckon more hot water on the final fit would sort it.
This shows that there is a need for Mike Elliotts new book. Did I buy this boat too early or is he writing it too slowly?
Any thoughts please? Even if you’ve never done this you might have some useful thoughts.
Sam
Sam
