The aluminum bang strip along the bottom of the keel on the "52" Yankee is wider than the narrow bottom of the keel. Should I plane the keel down to where the widths are matching or file the width of the strip. Planing the keel down a tiny bit to match the width is much less work. I do not believe that a slight reduction in height is going to be of any significance. Also none of the screw holes line up, so filling and redrilling is in order. This leads me to suspect the the keel strip was off a different canoe and the original owner (deceased) changed strips. The bow and stern strips are copper and were poorly fit, only bent between the screw holes. Very different with the "29" HW where everything I know for a fact is original and all lines up. Any thoughts of fitting the strip to the bottom of the keel are appreciated. Hope to have the Yankee done for the "PRESIDENTIAL PADDLE" next Saturday with all my mistakes intact. At least it isn't sinkling or taking on water.
