16’ Old Town
Chuck Cossaboom
Looking for build sheet on a 16’ # 139697 or it could be 139597.
Chuck
The Old Town with serial number 139697 is a lapstrake motorboat and 139597 is a 25 foot long war canoe model so those aren't a good match. My guess is that you probably have serial number 139591. This is a 16 foot long, AA (or top) grade, Yankee model with red western cedar planking, open ash gunwales, ash decks, ash thwarts, ash seats, half ribs, a keel, outside stems, and rub rails. It was built between March and May, 1944. The original exterior paint color was orange above the rub rails and green below. It was shipped on June 8th, 1944 to Auburndale, Mass. A scan of this build record can be found below.
It is also possible that you could have another number or manufacturer this description doesn't match the canoe. The link below is for an identical canoe that shipped on the same order. Feel free to reply here if you have any other questions.
Chuck,
After you get the canoe home post a couple pictures. I'm curious if it was caned seats or slat seats being a war time build. It was shipped from Old Town two days after D-Day. My father, at 18 years old, was in the middle of the Atlantic at the time on his way to Europe.
Jim
My research so far shows that slat seats were installed on Old Town canoes from serial numbers 140672 to 148222 which is about November, 1944 to May, 1947. This canoe is slightly outside of that range. They also appear to have occasionally used another woven material that was like cane from serial numbers 138142 to 141152 which is about October, 1943 to February, 1945. Examples of this material and a slat seat are shown below.
Chuck,
Jim
Picked it up today
This canoe doesn’t answer your question one of each,
Needs 12 ribs, 5 half ribs, 25’ of planking, rub rails, outside stems and bands.
Chuck, just a question about the slat seat.
Is it possible someone turned over the seat frame after the cane was damaged, cut out the cane, and added slats?
A look under the seat may provide an answer.
Good idea but it looks like the seat has always been a slat style, underside is still rough and looking at the bolts I would say this is the original seat.
