152736 18
The Old Town canoe with serial number 152736 is an 18 foot long, AA (or top) grade, Otca model with open mahogany gunwales, half ribs, a keel, and outside stems. It was built between April,1949 and April, 1951. The original exterior paint color was dark green enamel. It shipped on April 29th, 1951 to Mount Gretna, Penna. A scan showing this build record can be found by following the link at the attached thumbnail image below.
This scan and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and http://store.wcha.org/WCHA-New-Membership.html to renew.
