151886 18
The Old Town canoe with serial number 151886 is an 18 foot long, CS (Common Sense) grade, Guide model with white Maine cedar planking, open spruce gunwales, and a keel. It was built between October, 1948 and January, 1949. The original exterior paint color was G. S. (Guide's Special) green. It was shipped on February 18th, 1949 to Detroit, Michigan. A scan showing this build record can be found by following the link at the attached thumbnail image below.
This scan and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and http://store.wcha.org/WCHA-New-Membership.html to join.
