Conundrum
shelldrake
Good morning, About six years ago I built an Atkinson Traveler. The boat has been essentially unused since then and has hung inverted in an insulated garage. Recently I have been noticing the appearance of dark lines on the exterior paint which I'm quite sure correspond with the hidden plank butt joints. Upon closer inspection this morning, I'm also seeing the appearance of some hrizontal lines at plank seams. See attached photos.
The canoe was planked with quarter-sawn northern white cedar and ribbed with flat-sawn NWC. The interior was sealed with Interlux Schooner varnish thinned 40% with Interlux 333. A day later, the exterior was sealed with hot boiled linseed oil. Canvas(two weeks after linseed oil) was Rollin's treated 10 oz, filled with his filler. Primed with Interlux Pre-Kote(I think). Painted with Kirby's Light Gray and Light Green.
The lines do not wash off with soap and water and appear to be print-through of the linseed oil perhaps?
I spoke with Rollin about this this morning and he indicated that he had never encountered such a thing. Nor have I, although all of my previous restorations have either not had the exterior sealed, or I used thinned varnish, not linseed oil.
Any experience with such a thing among the Brain Trust?
Perhaps test with rubbing compound or even very fine sandpaper to see if the problem is only on the surface rather than through the entire canvas/filler/paint. If it's only on the surface, a good buffing could remove it. Linseed oil is often made a culprit with little or no evidence, but the culprit could be any number of things.
Butt ends of planks and joints between planks are different not only because they could hold more sealer, but also because they can be more open to air movement. This could lead to slightly increased condensation of water on the paint surface at those lines with weather changes. Also, garages are often full of chemical fumes, even if at a low level - fumes from the lumber, OSB, and sheetrock building components, and from stored chemicals. Any of these could be interacting with those open space in the planking. The point is that (1) switching to something other than linseed oil may not solve the problem, and (2) being kept in a closed space for years may have exposed the canoe to things it otherwise might not have been exposed to. [NOTE: I'm not a protector of linseed oil or anything else; just trying to think logically about the possible culprits.]
About chemicals in closed spaces, in a garage I once used, something degraded the urethane tires on everything there, degraded to the point of disintegration. These weren't a single batch; they came with a tables, they were on multiple batches of casters I ordered, and even the urethane tires on a bandsaw. I have no idea what caused it, but it happened only there. In another place (not on the coast, not near salt water), something caused rapid and dramatic rust on anything steel.
Bottom line - buffing might help in the short term, fresh paint might be required in the longer term, and getting more air circulation might solve the problem more generally.
I have encountered a similar situation. Not stains, but bumps from varnish that during hot/cold, moist/dry cycles had caused varnish to be squeezed out of the seams. The worst time, I tended to think it was because I varnished after canvas stretching where varnish seeped into the canvas. If you varnish after canvas, that could be the culprit.
Hmmmm. Well, I do have an old Jeep CJ7 parked under the canoe. It runs pretty rich...............
I also have an E.M White Guide hanging out there. I don't see any lines on it, but It has dark blue paint. It is also not hanging over the Jeep.
Long ago, I did not finish the interior before canvassing. Occasionally, either the stain or the varnish or both would affect the canvas and filler at the planking cracks. This appears to be a similar condition.
I checked my notes. I applied two sealer coats of thinned varnish to the interior prior to canvasing. Four coats of un-thinned varnish went on after canvassing. No stain. For sure, something, either the varnish, or the linseed oil I'm guessing is causing this.
Now that I can see the pictures, I would agree that it appears to be varnish. If coats of varnish are applied to the interior before the filler on the outside is completely cured, and it gets between the planking seams, it appears that the varnish can leak into the filler and soften it up and discolor the paint. I'm not sure of the science there but I just have witnessed the effect. It happened to me enough times that for many years I do just about all the interior varnishing before the canvasing and don't do any varnishing before the filler has completely cured, which for me is six weeks. I'll put on the last coat varnish some time latter.
Time will harden everything and then it can be repainted if the appearance is too distressing.
Unless- one more thought ... If the linseed oil on the outside of the hull was put on real heavy and the canvas put on before it had a chance to soak into the wood, maybe the oil soaked into the canvas and cause the same effect as the varnish would have. The oil or the varnish does pool up at the seams more that most other areas.
Strange things happen. This is a canoe I picked up a few years ago. I was pretty surprised to see the Douglas Plaid.
I tend to varnish the inside, let it sit for a while before applying my warm mix of turpentine, linseed oil and mineral spirits. Then I wait even longer before I canvas. I work at a snails pace most of the time.
Looking back at my notes, the process was:
- Interior seal coat of thinned varnish
- Heated linseed oil exterior one day later
- 2nd coat of thinned interior varnish 4 days after the linseed oil
- Canvassed/filled 10 days after the 2nd varnish interior coat.
- 4 coats of interior varnish 6-7 weeks after filling canvas
One of these days I'll get the boat down and re-paint it.
That would certainly seem to be a perfectly reasonable schedule but something appears to of soaked into the filler. There are just too many things to go wrong. You need a chemist and an engineer with every quart of paint!
I have developed some of these on my canoes years after restoration as well. Not as dark as yours and seem to bleed through the paint as well. My interiors were all finished before canvas was applied so I don't buy into people's comments about varnish.
Zack
Zack, your comments support my earlier thoughts. I don't doubt that oil seeping into uncured filler might generate problems in some cases, but other things might cause problem as well. Mike's photo of the "plaid" canoe above is one example, and another that many of us have experienced is a canoe upside down in light morning dew where you see the rib/planking pattern in the condensation (for example, see the attached photo by Mike Livdahl). The difference in hull thickness between ribs and planks causes a difference in how the atmosphere interacts with the exterior surface, and so it is perfectly reasonable to think the same of the planking junctions between ribs. Over time, something as simple as different amounts of atmospheric condensation in certain areas of the hull (just like patterns of oil seepage) will likely eventually cause patterned paint issues.
Bottom line, I'd bet most anything that there are multiple causes to the phenomenon and so it may be very difficult to determine what caused it in any given case. Best for the builder/restorer to take care with the finishing process as people outlined above, and best for the owner to keep the canoe inside if possible, but in an environment with good fresh air circulation. Such ideal conditions are probably rare and even with diligence, problems with paint may still show up. If they do, just know that the surface can be repaired - possibly buffed out and hopefully in the worst case, just sanded and re-topcoated.
Lightning Lake beach scene by Mike Livdahl, from the Fall 2025 newsletter of the WCHA's Northwest Chapter.
Yup.........we'll never know what really happened. I'd guess that the stain is present all the way through the canvas profile, in which case buffing-out won't remove it. So, I'll either re-paint, or leave it alone as a conversation starter. Time will tell.........
