Serial Number Search
maf0119
I have a red wood canvas canoe with the serial number 49-4115. Trying to find out more about this canoe. It’s 16’. The serial number is located at the bottom front of the boat. Stamped on wood at the seam. I can’t find any decal or name of who might have made it. Any info on this would greatly be appreciated. Thank you.
What would be the value of it today?
The information at the link below and similar canoes listed at https://www.woodencanoe.org/classifieds should help you value this one. An important factor will be how much it leaks, which usually requires a water test. A confirmed Seliga canoe will often sell for slightly more than a similar one from another maker. Can you supply a picture of the serial number? The image below is from a canoe with the outline of an original Selega decal on the deck. Let me know if this doesn't answer your question.
The closer you are to Ely, the more the value.
Piragis Outfitters had them priced $7k-$10k at one time, not long after Joe passed away.
