Looking for info on No. 96107
spencerpope
Hey folks, was wondering if anyone had a high-res version of this document. Trying to figure out the exact model and other info. Thank you!
Well, the build record is for a square stern model and the pictures show a canoe with two pointed ends so that isn't a good match. Can you provide some pictures of the numbers and surrounding areas from each end? It looks like an Old Town canoe from the mid-1920s to the mid-1930s. The suggestions at the link below may help if the numbers are hard to read.
Thanks Benson, that's exactly what I was suspecting.
I found the serial number- 108594 is what it looks like.
The Old Town canoe with serial number 108594 is an 18 foot long, CS (Common Sense or middle) grade, HW model with red western cedar planking, open spruce gunwales, birch decks, birch thwarts, birch seats, and a keel. It was built between December, 1930 and February, 1933. The original exterior paint color was dark green with a white hair line stripe. It shipped on March 9th, 1933 to Long Island City, New York. The paint cracked and peeled so it was returned and repaired from July to August, 1933. It shipped again to Springfield, Maine on August 15th, 1933. Scans showing both sides of this build record can be found below.
These scans and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others. A description of the project to preserve these records is available at http://www.wcha.org/catalogs/old-town/records/ if you want more details. I hope that you will donate, join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-wcha to learn more about the WCHA and https://www.woodencanoe.org/pricing-plans/join to donate or renew.
