old town with serial number 64558 17
phschmidt
I am working on restoring an old town sn 64558 17. I am wondering what year was made and color or other information on its original configuration.
Picture of the SN
Welcome and congratulations, the Old Town canoe with serial number 64558 is a 17 foot long, AA (or top) grade, Ideal model with red western cedar planking, open mahogany gunwales, mahogany decks, mahogany thwarts, mahogany seats, half ribs, and a keel. It was built between January, and April, 1921. The original exterior paint color was black. It shipped on May 20th, 1921 to Valley Park, Missouri. A scan showing the build record can be found below.
It is also possible that you could have another number or manufacturer this description doesn't match the canoe. Feel free to reply if you have any other questions. Good luck with the restoration,
Finally getting into the restoration. I have some mahogany wood for a missing Thwart. Not sure I like how it has turned out. I used one of the other ones as a template. Also, previous owner had added eye bolts on bow and stern that I do not believe are a item on original old towns. I used the sanding dust from the thwart and some wood glue to fill them in. Not sure if I'm going to have to make totally new ones. Attached are photos. Any suggestions or advice is appreciated.
I'd suggest reaching out to someone near you who has an Old Town from this era. Neither of the two thwarts shown in your photo are original. The shape of Old Town thwarts changed over the years, so it would be good to attempt to replicate one from the early 1920s for your canoe. On the other hand, thwarts can be replaced at any time, so if you just want a useable canoe, you can think about this later (if ever).
Not sure I have a '21 Old Town but will see. If I have a thwart as a template I will let you know and send an outline.
First, right on for removing those deck abominations. You are correct. They do not belong, although it is not unusual for people to add all kinds of bazar deck contraptions and in doing so, ruin perfectly wonderful decks, or breasthooks as those "boat people" like to call them.
I'd be inclined to plug those holes with some mahogany. You should be able to remove the paste you made and insert a few plugs made from some of that errant thwart wood. If you get the right piece of wood and rotate the grain to match, you should almost be able to make those holes disappear.
That will be a really nice canoe when you finish it. The AA's are real "lookers" and the Ideal is a nice hull to paddle.
Thanks all. The Thwarts on the 1921 Old Town Molitor look about like the ones that were on my 1921 Ideal. I will definitely need to work on the one I'm trying to fabricate... Also thanks for advice on the decking. I'll try to use a plug and just drill out the paste.
If you can take a close up of the grain I may have some mahogany around I could send you for "plugs" if I can find a close match.
Did one of the two thwarts in your first photo come off the canoe? I ask because neither one looks original for a 1921 Old Town, or any Old Town for that matter. Both are distinctly different from the correct shaping. Just saying this so that you might seek out a true original to replicate or to have replicated.
Here's one for you. I was continuing the cleaning of the varnish and found two cracked ribs. Question now is can this be repaired in place or do I need to do more disassembly and fabricate 2 new ribs? Any advice appreciated.
It's personal preference. You could do a back side repair. Carefully remove planking to get the area and mortise a patch. Replacing a rib is straight forward. Matching color is the challenge that I've never quite mastered.
Very possible that it is 3 ribs…..
Cut a 1/8” hardwood patch. Pre-bend it to the contour of the rib. Chisel a mortise about half the thickness of the rib to accept the patch. Make a backing block for the inside of the rib. Apply FlexEpoxy to the mortise and clamp it along with the back support block.
You may want to make the backing block first. Use it to maintain shape. Epoxy and clamp the block and crack to give it stability when you chisel the mortise pocket.
I like diamond or rounded hardwood patches. Eliminates the stress riser of a square end on a rectangle.
I’ve done hundreds of backside repairs with no known failures.
Or you could replace the rib.
I vote with Dave Wermuth and Dave Osborn. This is a good candidate for a backside repair. You have 2 ribs right next to each other, so removing planks gets you access to both. And, the cracks are right on the gap between planks, so the area you are fixing is centered between those 2 planks. And, you won't have to color match new ribs. One more and: if don't do the greatest job, it doesn't show!
