Rail Caps and Side rails on a Morris
Just found this posting from Scott Rowe on 6/20/2018: https://forums.wcha.org/threads/morris-open-gunnel-short-rail-cap-dimensions.15523/
Very interesting. I'm restoring a 17' Morris (#14067), and its deck & rail tips looks identical to the pic provided by Michael Grace (the 5th reply). Michael provided very very good information on the dimensions of the rail cap - especially on the 'inlet' at the start of the deck.
Now what can you folks tell me about the side rails? What were the overall dimensions? I'm guessing ~1" x 3/16". And did they taper a bit as they reached the pointy end of the deck - and if so when did the taper begin and how much did it taper?
Here's the pic Michael supplied:
Hi Howie, I have Morris #5873, a 17', Model A, Type 3, so all Mahogany with long decks closed gunwale. I believe the side rail trim is the similar to the top trim. Mine is 1" wide and about 1/4" thick with 1/4" radius roundover edges. The ends do tape over about 2' of length to about 5/8"-11/16. I'm guessing they were steam bent since they have held the curve for quite some time while off the boat. Hope that helps.
Reed
The link below has the dimensions and pictures of two Old Towns with closed gunwales from 1914 and 1919 if that helps. These may be similar to your Morris. Good luck,
Hi Howie I have a 1913 Kennebec closed gunwales with a splayed stem and riveted stem bands so it’s almost a morris the rail caps top and bottom measure the same mine are 15/16 wide and 3/16 thick they taper to 3/4 wide at the tip they start to taper at 19 - 20 inches from end of canoe. The caps most likely start out at 1 in but after rounding edges winds up 15/16
Good luck
Bruce
Thanks folks. I continued searching through the threads after I asked for help, and rather quickly found that I had asked the same question a few years ago with another Morris. One would think I'd take notes...
I'll be doing 1"x1/4" caps and 13/16"x1/4" rails. I had some 10ft cherry I took as partial payment on a canoe a few years back and just milled out the needed pieces. They're in the pool now soaking up water. I'll bend the rails in a few days (and make good use of these 90deg days). We'll see if they crack!
BTW... I always make forms for bending the last few feet of rails (instead of bending on the canoe itself) and I found a form that I had made a several years ago for a Penn Yan Rainbow that exactly matches the curve on this Morris. Interesting that this Morris and the Rainbow had the same upsweep at the at the decks. But of course the profile of the stems are different.
Here's another question: Do you folks varnish the inner surfaces of the caps & rails? I always do as I feel that's a great way to help stave off rot. Bending on a form allows me to exaggerate the bend the wood needs to take spring and takes spring-back into account. But I don't how you deal with spring-back if you bend on the canoe itself. So I'm thinking that when bending on the canoe you must screw or tack the caps/rails in place once the wood has sat there long enough. Which means that the inner surfaces don't get varnished. Am I wrong? Certainly I've never seen a canoe from a manufacturer where the caps/rails were varnished on their inner surface.
Timely question. I just this afternoon re-installed a mahogany outwale that I had previously steam bent on the canoe (directly on the filled canvas). After shaping the squared/rabbetted stock, I shaped the profile on the canoe. After a week or so to dry fully I removed them, sanded, colored, and varnished the rails... back side too! I just re-installed the first one this afternoon, and while it did not retain its full curve, it was enough to easily install on the fully painted canoe. There's a little bit of beeswax on the screw heads here and there...
Patrick: Sorry - I wasn't specific enough with my question. I can see how you can bend your rails on the canoe, let 'em take a set, remove them, varnish the inner sides, and reinstall them... because they have a very gentle upsweep bend to them. Here's my Morris in the foreground and a Thompson Hiawatha in the background. Now there's a bend with some springback!
Nice job on the canoe BTW!
Dan, clocking the screws is something I've never thought of. My concern would be that rotating additionally to make all slots line up might overstress the spruce inwales; maybe induce tear out and weaken the hold? I have seen it done elsewhere, just haven't considered it.
I would be very surprised if a quarter turn (or less) difference in a wood screw would overstress or weaken anything. You can always back it out slightly if you are concerned about this. The rail screws in most Old Town canoes were originally clocked.
We're going to get Howie riled up. Talking about clocking screws gets him fired up.
I will confess, I also clock the screws on almost anything I work on. It's a force of habit and possibly why I use soap (or beeswax) on all of the screws I put in. If my counter sink is not deep enough to achieve the desired result, I will take the screw back out and give the hole another jab with my countersink.
Clocking the rails is not as important to my eye as getting the decks and fairings done. A few hours in the bow of a canoe with un-clocked fairing screws grates on me. My brain cell struggles to ignore it.
Thanks, this is interesting to know. Though I have no experience with Old Town canoes, this is going to change immediately! I have now acquired 4 free Old Towns... a 16' HW, 17' Charles River, and two 15' 50 pounders. One of the 50# is on my next to do list.
I guess I might give this clocking thing a try. We will see how hard it is to turn the most "out of time" screws on the canoe, and if my timid soul can stand the added stress!
MGC/Mike: I will not get all worked up. I will note though that I understand there now exists drugs that successfully treat people on the spectrum.
  • Haha
A note of caution : If you "time adjust" on the PM end of the screw slot you will probably never have to rotate very much. It will be the case though that if you are one of the unfortunate few who are AM challenged, there are not yet any medications offering the slightest hope for a cure or even a mitigating of the difficulties associated with this intractable affliction. So do remember, the counter sink is your friend, and you are not alone.
We won't consider here the issue with some antique screws with abnormal slots.
And lest you think you can get away with not clocking your screws if you plan to bung them, rest assured you will be haunted in your dreams unless you do.
Ok, ok... But what about my question about how folks deal with springback if they steam bend on the canoe itself. Do they screw/tack the parts in place when dry - and leave the inner side of the part unvarnished and unprotected? Or do they eventually remove the part, varnish the inner surface, and reattach the part to the canoe - and deal with springback manually.
