The bolts are fin-neck as other have said. I've pulled them from a number of old Maine canoes. The fins are wide and work well to prevent turning. The British rib-neck bolts probably wouldn't hold well, at lest in softwood. In hardwood, especially if the fit is tight, maybe so. McClave Philbrick & Giblin in Mystic, CT also once sold something similar; maybe they still do. I'd have to go look at my stock but I think the fins are under the head of the bolt, not along the shaft.
As for the mahogany, those filler stains look horrible to me. There are two other options that produce a beautiful finish. First you can wet sand with oil (Tung or whatever you choose), and then wipe off excess across the grain, leaving the sanding swarf to fill the grain. Because it's oil and sanding dist from the very wood it's filling, the results are excellent. The other thing is to sand well and then build up coat after coat of varnish with some wet sanding in between. I've used both methods many times on old mahogany, new mahogany and other open-grain wood, and the results are a mirror finish. To me there's nothing more beautiful than that rich darkness of antique mahogany (well cleaned, of course). Muddying it up with filler is something that I'll never do.
