The Old Town canoe with hull identification number XTC23449M79H and serial number 223449 is an 18 foot long fiberglass Laker model that weighed 84 pounds. It was built between December, 1978 and March, 1979. The original exterior gelcoat color was desert white. It shipped on March 20th, 1979 to Concord, Massachusetts. The back side of the record indicates that it was purchased on June 10th, 1979 and the warranty card was returned from Westford, Massachusetts. Scans showing both sides of this build record can be found below.
These scans and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/catalogs/old-town/records/ if you want more details. I hope that you will donate, join or renew your membership to the WCHA so that services like this can continue. See https://www.woodencanoe.org/about to learn more about the WCHA and https://www.woodencanoe.org/shop to donate or join.
