Willits 774
ppride
Canoe Builder
I am looking for 16 Willits finish washers for the seat attachment screws. Attached is a picture of one. It measures 11/16 dia. with a #10 size screw hole which is counter sunk and the edges are beveled. Thanks, Pete
You can start by using a countersink to put the taper on the inside whole while holding in a vise or pair or pliers. Then you use a bolt with a tapered base and bolt the washer against it with a nut smaller than the washer. They simply turn the bolt in a drill and file the outside edge at the correct angle.
That's how I make them.
Good luck,
Paul
Thanks all, I ordered a couple of sizes of washers from Jamestown Suppliers and will use Pauls technique to get what I need. Pete
