Thompson Decks, are the interchangable?
workingbadger
Mad Badger
In Memoriam
I have a 16 foot Thompson Hiawatha. The hull is toast. But the decks are salvagable. My question is, will decks from a 16' Hiawatha, be an exact fit for a 15' Thompson Hiawatha?
DO you think they are the same length, or would the 17 footer's be longer?
The difference, if any, would be minimal.
You should be able to easily interchange, with possibly a little tweaking as mentioned earlier.
To me, the width is probably what may differ...but again, you should be able to fit it easily with adjustments if needed.
