SS Research 1908 & 15
John Boynton
Hi,
Not sure if researching my serial number correctly but on one stem #15 is imprinted and the other #1908. The boat measures 14'8". I realize 1908 is popular year as is 15' length so could be coincidence or I have SS1908 and it's a few inches short of 15'.
Appears to be early closed gunwale.
Any insight would be great. Image attached.
Grateful in advance,
John
Can you provide some pictures of the serial numbers from each end. The font can be an indication. Some other pictures could help as well like Dan suggested. Thanks,
Here are a few more images. Thank you! Short stem image includes the #15 - but very hard to read. Longer Stem is the #1908.
Adding a few more. Thank you Dave!
Thank you Benson - indeed that is my brother. Didn't realize he had requested...yes it is the same canoe. As you can see our restoration hasn't advanced. Believe it's actually time to send it down the river to a new owner.
Thank you Benson - I assume this canoe falls into one of the following categories from the linked thread:
Basket case canoe: $Free- $200.
Restorable, not too bad: $200 - $500
I agree that this canoe appears to be is solidly in the free to $500 range. The determining factors will probably be how anxious you are to get rid of it, the location, and how many broken ribs (and other parts) it has. Many of these breaks may not be obvious until the varnish is removed. It appears to have had a stern quarter thwart added which is usually a sign of an attempt to quickly fix a problem in the past. See https://www.wcha.org/forums/index.php?threads/3968/ and https://www.wcha.org/forums/index.php?threads/15877/page-2#post-82173 for a canoe that I once owned which had a similar fix.
