Several Serial Numbers
Scott Barkdoll
I need history on the following serial numbers
111 724-34 - this is a very old weathered war canoe. I'm not sure whether there are 1,2, or 3 ones at the front. It is from Michigan and is at least 34 feet long.
98496-25 This is a 25 foot war canoe from Vermont
117 522-25 This is a 25 foot war canoe also from New England
20904-17 This is a closed gunnel canoe
128875-16 This is an AA grade canoe
172030-20 This is a 20 foot guide
18009-18 or 18209-18 Both ends are double stamped where the first 0/2 is. I don't know which number it is supposed to be. This is a closed gunnel CS grade canoe.
Scott
The Old Town canoe with serial number 111724 is a 34 foot long, CS (Common Sense or middle) grade, war canoe model with red western cedar planking, open spruce gunwales, thirty inch decks, birch thwarts, a keel, outside stems, and a floor rack. It was built in June, 1932. The original exterior paint color was dark green. It shipped on June 15th, 1932 to Plainwell, Michigan.
The Old Town canoe with serial number 98496 is a 25 foot long, CS (Common Sense or middle) grade, war canoe model with red western cedar planking, open spruce gunwales, thirty inch arched decks, birch thwarts, birch seats, a keel, and a floor rack. The original exterior paint color was bright red. It shipped on June 22nd, 1929 to Dresden-on-Seneca, in Yates County, New York.
The Old Town canoe with serial number 117522 is a 25 foot long, CS (Common Sense or middle) grade, war canoe model with red western cedar planking, open spruce gunwales, thirty inch birch decks, birch thwarts, birch seats, a keel, outside stems, and a floor rack. The original exterior paint color was dark green. It shipped on May 21st, 1937 to Plymouth, Mass. It was extensively damaged is shippment and was returned on July 20th, 1937 for repairs. A new canoe was shipped to replace it and this one was shipped on June 23rd, 1941 to Ashville, New York. It may have moved to Baldwinsville, New York by September 3rd, 1981 when there was a previous request for a copy of this build record.
The Old Town canoe with serial number 20904 has already been described at http://forums.wcha.org/showthread.php?9777 with a copy of the build record.
The Old Town canoe with serial number 128875 is an AA (or top) grade, HW (heavy water) model with open mahogany gunwales, mahogany decks, mahogany thwarts, mahogany seats, a keel, and a floor rack. It was built between January and August, 1941. The original exterior paint color was dark green. It shipped on May 23rd, 1941 to Williamsburg, Virginia.
The Old Town canoe with serial number 172030 has already been described at http://forums.wcha.org/showthread.php?4341 with a copy of the build record.
Scans showing all of these build records can be found by following the links at the attached thumbnail images below. These scans and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and http://store.wcha.org/WCHA-New-Membership.html to renew.
It is also possible that you could have another number or manufacturer if these descriptions doesn't match your canoes. Are you planning a battle with all of these war canoes? Feel free to reply here if you have any other questions.
Your last canoe may be a bit of a challenge. The Old Town canoe with number 18009 is an 18 foot long, GS (Guide's Special or low) grade IF (Indian or ideal fishing) canoe model with red western cedar planking, closed spruce gunwales, ash decks, ash thwarts, ash seats, and a middle thwart. It was made between June and July, 1911. The original exterior paint color was dark green. It shipped on July 11th, 1911 to New York city. The Old Town canoe with number 18209 is an 18 foot long, CS (common sense or middle) grade HW (heavy water) canoe model with red western cedar planking, closed spruce gunwales, ash decks, ash thwarts, ash seats, and a middle thwart. It was made between June and July, 1911. The original exterior paint color was dark green. It shipped on July 10th, 1911 to Plattsburg, New York. The most obvious differences between these two canoes would be the sheer line. The HW had much higher ends at the points than the IF model did. The Carleton canoes with these numbers are both 17 feet long but the Kennebec with serial number 18209 was their 18.5 foot long Guide's model. The last two paragraphs of my previous message also apply to this one. Please post a picture of the side view if you are not sure.
