serial number lookup
Congratulations, the Old Town canoe with serial number 14535 is an 18 foot long, CS (Common Sense or middle) grade, HW (Heavy Water) model with red Western cedar planking, open spruce gunwales, ash decks, ash thwarts, ash seats, and a keel. It was built between July and October, 1945. The original exterior paint color was dark green. It was shipped on October 25th, 1945 to Cleveland, Ohio. A scan showing this build record can be found by following the link at the attached thumbnail image below.
This scan and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and http://store.wcha.org/WCHA-New-Membership.html to join.
It is also possible that you could have another number or manufacturer if this description don't match the canoe. Feel free to reply here if you have any other questions. Good luck with the restoration,
