serial number info
The Old Town canoe with a serial number 187705 is a 15 foot long, Trapper model with half ribs and a keel. It was built between November, 1971 and January, 1972. The original exterior paint color was dark green. It was shipped on November 2, 1972 to Nanuet, N.Y. A scan of this build record can be found by following the link at the attached thumbnail image below.
This scan and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/wcha/ to learn more about the WCHA and http://www.wcha.org/join.php to renew.
It is also possible that you could have another number or manufacturer if this description don't match your canoe. Feel free to reply here if you have any other questions.
Al
Old Town 187705 is a 15' Trapper model finished between November 1971 and January 1972. It has half ribs and a keel and was originally painted dark green before it was shipped to Nanuet, NY, on November 2, 1972.
The scan of this record is attached below-- click on it to get a larger image. This scan and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/wcha/ to learn more about the WCHA and http://www.wcha.org/join.php to renew.
Double the Fun
Well, I needed the practice.... finally have my new computer set up for the second time, and this was the first scan search.
