Serial number info
The Old Town canoe with serial number 163569 is a 25 foot long, CS (Common Sense or middle) grade, war canoe model with a keel and outside stems. It was built between May and July, 1955. The original exterior paint color was dark green. It shipped on July 6th, 1955 to Toledo, Ohio. A scan of this build record can be found by following the link at the attached thumbnail image below.
This scan and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and http://store.wcha.org/WCHA-New-Membership.html to join.
