Serial number help
The Old Town canoe with serial number 104274 is a 16 foot long, CS (Common Sense or middle) grade, HW (heavy water) model with red western cedar planking, open spruce gunwales, a keel, sponsons, bilge keels, and a bang plate along the full length of the keel. It was built between December, 1929 and April, 1930. The original exterior paint color was dark green. It shipped on April 29th, 1930 to Hibbing, Minnesota. A scan showing this build record can be found by following the link at the attached thumbnail image below.
This scan and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and http://store.wcha.org/WCHA-New-Membership.html to join.
