Serial # 127062 17
You may need to take another look at this serial number since the Old Town build record for serial number 127062 shows a 16 foot long double ended boat and the 17 on the end of your number implies a 17 foot long craft. Can you confirm the extreme overall length in a straight line and provide some pictures of the inside stems from each end showing all of the serial numbers and the areas around them? The information at http://forums.wcha.org/showthread.php?791 may help with the digits that are are hard to read. Which digit is the least clear? Good luck,
well the 17' is the most clear so I think that's right
i will double check the other numbers and use the guide you suggested.
i hope these photos work. it is a sailing vessel i think
137062 17 revised
I did the low light trick and it sure looks like 137062 17
here is a picture. The 17 is very clear and not in the photo.
thanks so much for your expertise.
Steve
The Old Town canoe with serial number 137062 is a 17 foot long, CS (Common Sense or middle) grade, HW (heavy water) model with open spruce gunwales, ash decks, ash thwarts, ash seats, a keel, and sponsons. It was built between February and April, 1943. The original exterior paint color was dark green. It shipped on May 12th, 1943 to St. Louis, Missouri. A scan showing this build record can be found by following the link at the attached thumbnail image below.
It is also possible that you could have another number or manufacturer if this description doesn't match your canoe. The sail rig is not mentioned on the build record so that was probably added later. Feel free to reply here if you have any other questions. Good luck with the restoration,
