Roger - Thank you for your quick reply. The canoe in question matches up almost perfectly with the build record, except in one regard. You mentioned in your response that the build record indicated open gunnels, and the canoe itself has closed gunnels. Yet when I look at the attached image of the build record, I see only that the rails are spruce. So, my question is - how did you ascertain that the canoe should have open gunnels? What am I missing here? Everything else seems to fall in line perfectly, and it sure looks like an OT HW. Thanks again for your thoughts on this - it sure seems like we may have a match here, but I would like to know for sure. LEW
