MGC
Scrapmaker
This past summer I brought an older canoe out of the rafters to paddle.
Before I used it I cleaned it up and also gave the paint a quick and pretty gentle rubdown with Penitrol. It really brought the color back up nicely.
At the time I remember thinking that I should give it another coat of paint at some point. The finish was in really good shape but it was showing some wear.
I originally painted the canoe with two coats of Pettit Shipendec Blue directly over the filler. I wet sanded the filler before painting and allowed it to dry for a long time after filling and also before painting.
After several days of paddling the canoe I noticed a couple very small spots where it looked like paint was lifting from the filler. I was able to rub the paint right off with very little effort.
Since then I have looked the canoe over and it looks like there are only a few very small areas where this happened. My current plan is to carefully sand the entire canoe and then repaint it.
Before I re-paint I am interested to hear comments about what happened and what if anything I should do to make sure the paint adheres. Was it foolish to rub on Penitrol?
This is the first time I have done this and the result (a fleeting but nice gloss) may not have been worth the consequences.
I am also curious to know what other paint I might use over the Shipendec since it looks like Royal Blue is no longer available. Would a Kirby paint adhere over the Pettit?
I will appreciate all advice about this.
Mike
Mike
