Old Town SN 163975 - can you provide build sheet
The seller is correct. The Old Town canoe with serial number 163975 is a 16 foot long, CS (Common Sense or middle) grade, Guide model with a keel. It was built between August and November, 1955. The original exterior paint color was G. S. (Guide's Special) green. It was shipped on November 22nd, 1955 to Troy, New York. A scan of this build record can be found by following the link at the attached thumbnail image below.
This scan and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and http://store.wcha.org/WCHA-New-Membership.html to renew.
It is also possible that you could have another number or manufacturer if this description don't match the canoe. Feel free to reply here if you have any other questions. Good luck with the negotiations,
