Old Town Dinghy 164191
Welcome, the Old Town with serial number 164191 is a 9 foot long, AA (or top) grade, Dinghy model with half ribs, a keel, and outside stems. It was built between October, 1955 and February, 1956. The original exterior paint color was white. It shipped on March 8th, 1956 to Boston, Mass. A scan of this build record can be found below.
It is also possible that you could have another number or manufacturer if this description doesn't match. Let me know if you have other questions or if there is anything else that I can do to help. Thanks,
Benson,
Thank you for the information! With the dinghy purchase came what I believe to be the original style Rowlocks with unattached safety chains. Can you possibly refer me to reference pictures showing how the safety chains are attached to the Rowlocks and the dinghy?
Thanks again for any further assistance!
Doug
This depends on the type of rowlocks and safety chains you have. Can you provide some pictures? Thanks,
See pic below. I’m told by others to open the end link of the chain and attach to the hole in the rowlock. The “T” end is fastened to the gunwale (or below) with some kind of clamp or braces screwed into the gunwale. I see no evidence (screw holes) on the dinghy that the chains were ever attached in this fashion.
Thanks again,
Doug
Those chains are used with a different type of oarlock. The page at the link below shows the "Oarlocks" and "Oar sockets" which use "Safety Chains" like that. The "Rowlocks" like yours can use any sort of small twine or chain to secure them. See page four in the document at https://wcha.org/classified-archive/Northwoods-Kingfisher-15-2012-6-24-21.pdf for an example of how your chains could be used.
I put a little brass eye screw in a rib below the row lock and a brass clip on the chain.
