The Old Town canoe with serial number 222110 is an 18 foot long Chipewyan Voyager model that weighed 85 pounds with aluminum inserts in the rails. It was built between June, 1978 and April, 1979. The original exterior color was green. It shipped on April 12th, 1979 to Belfast, Maine. The hull was thin so it was sold as "As Is" at a discount. A scan showing this build record can be found below.
This scan and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others. A description of the project to preserve these records is available at http://www.wcha.org/catalogs/old-town/records/ if you want more details. I hope that you will donate, join, or renew your membership to the WCHA so that services like this can continue. See https://www.woodencanoe.org/about to learn more about the WCHA and https://www.woodencanoe.org/shop to donate or join.
